USINE HOLLYHOCK RETINA SCREEN PROBLEM
Shintylla
Unread post by Shintylla » 27 Dec 2014, 12:54
my using is very grained as it doesn't support the screen resolution of my mac. Any case out there and/or solution??
Unread post by senso » 29 Dec 2014, 11:04
Usine supports retina displays.
moreover, usine is developed on a retina mac...
so you pb comes from elsewhere.
can you post a bug report with your logfile and scren shots?
thanks
Unread post by senso » 29 Dec 2014, 14:58
Nothing suspect on your screen shots
Usine use the basic retina mode and divide the resolution by 2, like almost all softwares, especially audio.
Also, inside usine we took the option to minimize antialiasing and so get the max of cpu for audio not for display. It's a choice, we can discuss about it but, the more you have resolution and fx, the less you have power for audio...
Shintylla
Unread post by Shintylla » 02 Jan 2015, 16:34
Thank you Senso,
I agree that is better have more power to CPU for audio than other things.
Users browsing this forum: No registered users and 480 guests
