This procedure (SET_TARGET_PATCH) rises some questions.
The manual says: "Define the target patch which will receive Internal Messages".
1. What happens exactly if more than one patch (or more generally, subpatch) has the same name in the workspace?
subsequent question: is it possible to give to a patch a name different from the one displayed as caption in the caption bar? or name=caption?
2. It seems that the internal messages send with a 'Send Usine Internal Messages' module are only received by the patch where the module is, whatever any 'SET_TARGET_PATCH' procedure has set just before in the message (except of course using the 'SENDER_PATCH' variable). Do I misunderstand its use, or its syntax, ore something else? Or does it work for some procedures and not for some others? Or does it really have some effect?
Thanks!
Best regards,
Vince
Questions about the IML procedure 'SET_TARGET_PATCH'
vincent michel
composer & novelist
composer & novelist
i have to investigate about this names question.
1,2) SET_TARGET has no real effect in HH, will have in HH2. Patches are found by their name and if several patches have the same name, Usine takes the first found (in order of creation)
senso++++
senso++++
Hi you both,
Thanks for your answers. More clear for me now and... waiting for HH2!!!
Kind regards,
V
Kind regards,
V
vincent michel
composer & novelist
composer & novelist
Bummer. So we cannot set target patch by number???
My channel patches are all identically named.
I'm creating them with the load patch module. Was hoping for IML to behave like load patch, to allow selecting a rack # and patch #.
Users browsing this forum: No registered users and 34 guests
