different wkp = same OSClister ?
XpiR
Unread post by XpiR » 31 Oct 2014, 10:32
Hi
There is something I can't figure out about controlling Usine via OSC.
I use TouchOSC on a smartphone and I control my patches thanks to an OSC lister module.
But when I modify this OSC lister located in my Devices/In section, the change is efficient for ALL my workspaces. For example, I happened to erase the OSC lister in a workspace and then it got erased in all my projects.
Same for the OSC out...
Can't they be independant from one wkp to another ?
ceasless
Unread post by ceasless » 31 Oct 2014, 17:25
You will need to make individual device patches for any configuration you want. The device patches are global, but you can make a new one for any purpose you want, and they can all talk to the same hardware at the same time (at least unless I am mistaken).
XpiR
Unread post by XpiR » 31 Oct 2014, 22:26
Doyou mean something like that :
And you only activate the patch you need according to your workspace ? (here OSC in device 13)
Unread post by oli_lab » 02 Nov 2014, 16:57
big advantage of using devices instead of putting osc modules in racks is that they take ressources only when receiving or sendind OSC.
Users browsing this forum: No registered users and 74 guests
