Battery and Usine
noise2sine
Unread post by noise2sine » 01 Oct 2014, 09:13
I'm using Native Instrument BATTERY 3 with Usine V5.I have made a simple and cool patch to control Battery.But :)
I have created 54 faders in order to control the level of each cells, it is working fine but my wish now is to be able to see which cell is playing in the USINE interface ? I need this because i'm playing with the pitch of the midi file therefore everything is moving all the time, that's why something visual in order to show me what is playing,instead of turning all the fader on and off for finding who's playing :)
Unread post by nay-seven » 01 Oct 2014, 11:23
sadly this plug in don't send anything via the array output,
but i suppose you play it via Midi , so you can use a mapper data to transform Midi to matrix and create a visible matrix for feedback..?
noise2sine
Unread post by noise2sine » 01 Oct 2014, 11:44
Sounds like a great idea ! how can you make that ?
Unread post by nay-seven » 01 Oct 2014, 12:03
here a simple example, you have to edit the mapper data to suit your needs, here only the 4 first note are assigned
noise2sine
Unread post by noise2sine » 01 Oct 2014, 12:25
is it making a difference if i'm using a piano roll ? i have just a midi out, whereas in yr example there is code 1 and msg out ?
I didn't find the = module ? And for the matrix module there is a lot to choose in the list,which one do i choose ?
Unread post by nay-seven » 01 Oct 2014, 12:49
yes, you have to use an unpack module,
The A=B is in the match modules
And you have to use the user module matrix display
here the patch
