Drag and Drop Utility for Converting into HollyHock
sephult
Unread post by sephult » 03 Sep 2014, 23:48
I've been looking for quite awhile for an audio database software.
Unfortunately I could not afford BaseHead, which is an excellent application.
After some time I found MediaMonkey was actually a decent program, and the gold version is at least affordable.
http://www.mediamonkey.com/
Unfortunately, MediaMonkey (and quite a few others) uses drag-and-drop events as a Copy-Event, so HollyHock does not recognize them as valid.
Therefore I created a small C# Winform tool to convert the Copy-Event into a Link-Event that HollyHock would accept.
If anyone else was interested, and facing the same issues I had, the utility is located here.
http://www.sensomusic.org/forums/upload ... agPath.zip
Note* In Windows, if you are having drag-and-drop issues: check UAC and that the applications share the same elevation.
If HollyHock is run as an administrator and the others not drag-and-drop will give issues.
Quite possibly maybe this could be a future Feature request to update HollyHock to accept both Copy & Link events?
Until then,
Hope this helps others :)
-S
Unread post by nay-seven » 09 Sep 2014, 09:44
i don't know about this application but thanks to share your work anyway !
( and feel free to add your request in the suggestion forum)
Unread post by senso » 23 Sep 2014, 14:26
thanks to share
very useful for me++++
Users browsing this forum: Google [Bot] and 538 guests
