I know I can use IML to get the list of presets from the VST, but it's very clumsy--if a VST bank takes a while to load, I have to guess how long to wait before querying the VST for its presets. And so far the 'loading' output on the PM is not reliable for banks that take a while to load (like reaktor instruments with lots of sample data.)
Maybe there is a technical reason this is difficult to do, but it would sure be great to just have my list always correctly display the current preset names.
thanks!!!!
preset names output on VSTs?
I like this idea, too!
I may not need to display the vst at all with this feature.
