VSTs & Tempo
shawnb
Unread post by shawnb » 04 Aug 2014, 06:32
Hi all!
Within a patch, how do I feed HH's master tempo to a VST?
New to Usine here, working on my first patches. I'm using VSTs. I'm trying to do some programming for the parameters fed to the VSTs, and I would also like them to utilize HH's master tempo.
If I drop a VST in the workspace, tempo works great. But I can't seem to figure out how to put logic between the MIDI source & multiple VSTs.
If I drop a VST in a patch, I can put logic & control PCs, CCs, etc. But the VST doesn't respond to HH's tempo, it doesn't seem to respond to tempo when it's in a subpatch.
Is there some config I'm missing? I'd like to control tempo and messages to the VST; whatever I try, I seem to get one or the other.
THANKS!!!!
Shawn
shawnb
Unread post by shawnb » 04 Aug 2014, 07:22
Nevermind...
I just rebuilt everything from scratch & I can get tempo to work wherever I want now.
I was able to save my more convoluted patches, & just rebuild a new workspace. All is good.
I think I had done so much experimentation with settings along the way, who knows what wasn't setup correctly.
Unread post by nay-seven » 04 Aug 2014, 08:54
glad you find your way, and yes, once you find the good logic, it's always interesting to rebuilt from scratch.
Users browsing this forum: No registered users and 34 guests
