how to set a tempo?
magickz
Unread post by magickz » 02 Aug 2014, 10:20
I am still new to Usine and maybe it is still allowed to ask a stupid question: :/ I do not really understand why it always changes the speed and jumps to 429bpm during playback, and I wonder how to control this behavior or how to set the speed for example to 120bpm when I want to use the Piano Roll or Midi File Player to control a VST instrument?
sephult
Unread post by sephult » 02 Aug 2014, 18:56
Don't worry magickz, I've been using for quite awhile and still ask questions....lol
As far as the Tempo, that seems strange. Are you networking between two instances?
The only case where I found that I had accidently set send Tempo/Sync on both a Host and Slave.
Or are you just changing the Tempo from the Master Syncro?
magickz
Unread post by magickz » 03 Aug 2014, 09:07
Thank you Sephult.
Hm. That's weird. There is no master running. But, I deactivated all midi controllers in the devices panel and in the system settings (currently they are all in the drawer and only a midi keyboard controller M-Audio Oxygen is connected), and I deactivated LoopBe. So far I know, the Oxygen Keyboard has no clock... Then it seems to count more stable. I will try more later. Something must be the reason, why it changed the tempo with only firefox and usine running on my pc.
magickz
Unread post by magickz » 03 Aug 2014, 14:23
Thanks, Sephult. I think it was caused by LoopBe, because I forgot to disable the setting "receive time clock" - though I have no idea at all from where LoopBe should take the timing information if no other music related software is running, and I cannot reproduce this behavior for now. :)
Users browsing this forum: No registered users and 682 guests
