Sequencer VST Plugin in Usine not starting
magickz
Unread post by magickz » 28 Jul 2014, 06:41
Hello all. I am still very new to Usine. Just purchased it yesterday. One of the my tries was to run my favorite VST plugins in Usine.
I like to play with all kinds of sequencers, for example the Sequencer Megababy plugin from Reaper which can be downloaded for free with their free plugin collection - or the Monoplug B-Step sequencer. http://b-step.monoplugs.com/
They load well, but for some reason I cannot get them working by pressing the play button. It is as if they are missing some signal or impulse that they can start sequencing when I press play. Before I am going to try it with more different sequencer VSTs, I want to ask if there is a special trick that I must apply to get midi data out of this kind of plugins?
It seems to be no problem to control b-step with my launchpad. Usually it should start working when I press the play button in my daw, but here it is not the case.
Best regards.
Unread post by nay-seven » 28 Jul 2014, 11:24
Hello magickz and welcome
you're right, the synchro don't start with this plug in ( other sequencer like step machin for example, woks fine)
Don't know if it's a limitation of the demo version but in its setup i can change the master synchro to slave..?
have you try this..?
we'll investigate anyway
magickz
Unread post by magickz » 28 Jul 2014, 13:20
Hello Nay-Seven,
thanks for the answer. I guess that is the reason. It is not a demo version.
On the KVR website I can read their specification: "MIDI Clock master (up to 400 BPM) or slave (standalone)."
So, I also asked on the Monoplugs forum for their advice. As soon as I know a solution I'll report it here.
If there is no other way, maybe I better stick with some of the really nice Usine sequencers :)
Best regards, Martin
Unread post by nay-seven » 28 Jul 2014, 16:02
of course, it's a good idea to test and create your own sequencer in Usine, ( you can also find some good ones in the add _ons tab ) but this issue with the B-Step plug-in will be solved in the next release.
monotomy
Unread post by monotomy » 29 Jul 2014, 21:30
Hi nay-seven, senso-Team,
I'm the B-Step developer. If you have any question to solve this problem please let me know.
Best
Tommy
Unread post by nay-seven » 29 Jul 2014, 22:35
Hello monotomy and welcome
Congrats for your Plug-in , seems to be a great tool !
btw, as said in my previous post the team has find the issue and this will be solved in the next release ;)
monotomy
Unread post by monotomy » 30 Jul 2014, 00:41
Ups, sorry! I reading to fast sometimes.
Thanks for the flowers, but your DAW looks also nice!
All the best!
magickz
Unread post by magickz » 30 Jul 2014, 06:35
Thanks a lot!
I must say, after playing around with Hollyhock for a few days, and working through some chapters in the manual, it becomes quite addictive - and a great modular environment for my favorite modular synth. :)
magickz
Unread post by magickz » 24 Aug 2014, 12:43
Hello Nay-Seven,
I want to confirm that the latest update solves this issue with the B-Step Sequencer successfully. Thank you very much! That is very great. And I begin to love the Usine features more and more the more I understand how to make my patches. Now I can use them in combination :)
Edit: I took a few minutes time and prepared a short instruction for absolute beginners, to post it in the monoplugs forum. Here it is:
Best regards.
P.S. I do not know how to do it, but now you can change the topic headline into "Sequencer VST Plugin in Usine working great"
shawnb
Unread post by shawnb » 24 Aug 2014, 17:07
Thanks for the excellent support!
Unread post by nay-seven » 25 Aug 2014, 09:31
Thanks for your feedback and thanks for this well done tutorial , all communication around Usine is really appreciated !
magickz
Unread post by magickz » 26 Aug 2014, 14:37
:) avec plaisir
Users browsing this forum: No registered users and 807 guests
