have not been here for a while . . .
is it possible to make so that Usine loads at PC start up with definite workspace?
Auto load
Just drop a "file shortcut" inside the startup folder on the startup menu !
actually there is an autoload feature. It's in prefs: open with workspace or something like that.... unlike the v5, you can specify any wkp file, not just the 'most recent' (which usually wasn't the most recent for me...)
how can you open workspace from wkp file or shortcut? for me it opens just usine start page if associated with usine aplication.
But anyway thanks! I put Usine shortcut in windows startup folder + define workspace in usine startup prefs. And it works as expected
Users browsing this forum: No registered users and 48 guests
