preset manager not working in nested poly subpatch
Unread post by woodslanding » 08 Jul 2014, 21:01
This is my wkp gui. I'm trying to get total recall working.
I have a PM set to 'rack', and it will recall the settings for the params subpatches in the rack which are poly.
But the main gui subpatch has the widgets several levels deep in subpatches, and they are not recalling.
Before I post a bug report, can someone tell me if there is a setting I missed or something else I did wrong? I have all the subpatches set to recall presets.
EDIT: forgot link!
http://www.sensomusic.org/forums/upload ... orking.wkp
-eric
Unread post by woodslanding » 17 Jul 2014, 01:38
Figured this out. There are settings at the patch level, and among these is 'saved in preset'.
now I am truly SAVED!
