The filter module is handy, but how can I display freq and Q without using knobs or faders ? They have no pin out.
Filter module : diplay freq and Q ?
- nay-seven
you can use the mouse X and Y outlets
then a change scale to convert to freq and Q values and a fader ( transparent and show fader = off)
La Tenaille
I've tried but I can't find the good tuning to match the real values :
I've patched : mouse x >> change scale (0-1 to 50-2000) >> fader min 50 max 20000
and tried the 3 fader scales but it doesn't match the original values.
La Tenaille
Thanks Nay, but this doesn't work. If you compare the values in the module with the values displayed it's wrong.
- nay-seven
mm, right
i will investigate
i will investigate
- nay-seven
Maybe the patch " XY Filter" can do the job for you..?
