Grid Vision
Blaakk
Unread post by Blaakk » 24 May 2014, 20:12
Hola!
Is there an easier way to accomplish the following patch logic from scratch, or rather... am I missing something?
It's a little patch to change the next viewable gridline number, ie... 33 presets forward and backward. Was pretty much for display only, at least that was the initial thought. I realize that there's the maximum wrap to sort, and also the displays don't update when clicking the 'wrap?' switch.
What's an 'in call callback'? The workspace froze twice on me because of one of these. I had this twice but tried a third time and it exported (I know I could have just 'saved patch as'). And is this a typical, or sensible use for a 'data device'?
Here's the patch..... Grid Vision
Unread post by nay-seven » 26 May 2014, 10:57
Have you test the patch " current grid" in the library/usine panels ?
for the frozen question, if you can reproduce , feel free to create a bug report and join the file LogUsine.log created just after the crash.
Blaakk
Unread post by Blaakk » 27 May 2014, 01:02
Haven't been able to (accidentally) reproduce it. Yep, I've seen it before. But actually only searched in the other panels (modules and Add-ons for some reason this time round)
Yeah, there have been a few occasions....... Just felt up against the clock lately. I should just stop and ask a/the question, but I have this daft habit of trying to solve every little problem I face. Think it's me doing something wrong a lot of the time.
Speaking of Been having a problem.... Image
I'm trying to... when I trigger the top half the top half only route audio to the red looper but it's not working. I'm triggering the GRID with this: Image and the setting the grid to load a rack preset. which turns (or is supposed to turn off ) This is pretty much a setup within a usable state. Just need to iron out a few creases and I can look towards taking it to the stage (and expanding the hell out of it. I have the two RC51s (which are awesome btw :))
It's keep's 'forgetting' the automation. Not sure what I'm doing wrong. I'm having it each grid line recall a preset and set the 'pre' buttons. Each half should have it's corresponding colour's prefader lit. It works sometimes and not others.
Blaakk
Unread post by Blaakk » 27 May 2014, 01:21
There 's so much I'm looking forward to doing with this stuff... there was about 3 occasions today where i wanted to ditch the first half of a loop..... need to crack handling of wave displays.
Buying some i7s tomorrow,and and an SSD. Any recommendations for touchscreens? :)
Unread post by nay-seven » 27 May 2014, 08:59
again , not easy to help you on big workspace,
the best method is to isolate the problem, try to reproduce only the part where you recall preset ?
Blaakk
Unread post by Blaakk » 27 May 2014, 11:41
Ok cheers,I'll give at another bash.....
