FCB Boy (v1.2), for FCB1010 users. :)
Blaakk
Unread post by Blaakk » 22 May 2014, 17:37
Hey all.
I've uploaded an updated version of Patch. The 1st version only had one bank. It needed at least 2 for me to actually use it properly, so I hung on a little. This patch has 1 MIDI input, and currently 5 x 10 banks of either Toggles, Triggers, or Momentary Lapses (erm, latches) labelled as Toggle, Pulse, and Hold. Combobox at the top switches all 10 pedals at once.
There are also 4 expression pedal couplet switches, and the pedal's LEDs (on the control panel) reflect the current state of each. The FCB1010 should stay on bank 00, and transmit only a single 'Note Number' (notes 1 to 10) and the two expression pedals unchanged (set at CC11 and CC12).
I'm using it, atm, to control two modded RC-52's.... Juicy Loops I and II.
I'm controling JL1 with 1-10. When I switch to a Gridline occupied by Juicy Loops II, a different FCB Boy preset, with the 11-20 switch on is called. All bank switching is done via my iPad, or the Grid. Or control panel.
To do....
Make the LEDs light the color of the button type as opposed to all red.
Add more stuff.
A stomp-box mode.
Get a touch-screen and some i7s. :)
Feedback welcome! Hope someone else can use it.
Edit: will upload a more CPU efficient version in a day or two.
Unread post by nay-seven » 19 Aug 2014, 11:38
aarg, why i've sell this FCB :)
thanks to share this patch, i will adapt it maybe for a LPD8
Unread post by woodslanding » 19 Aug 2014, 16:16
I've got one I'll sell you......
I gave up on it, because the footswitch bank is monophonic. So you can't FI turn a looper on while holding down a pedal mapped to sustain.
Probably not worth shipping halfway across the world tho ;)
Users browsing this forum: No registered users and 5 guests
