Filtering out lowest midi note
awinterstale33
Unread post by awinterstale33 » 19 May 2014, 06:50
Hi, can someone point me in the right direction real quick. Im just trying to filter out the lowest midi note out of chords or a short sequence of chords?
Unread post by nay-seven » 19 May 2014, 10:18
Here an example for a chord or short sequences , the synchro will determine the calculation frequency
Download
awinterstale33
Unread post by awinterstale33 » 20 May 2014, 01:23
Alright cool thank you. I will check it out as soon as I get home! Basically I want to send the bass note of a chord to a different instrument in kontakt.
awinterstale33
Unread post by awinterstale33 » 20 May 2014, 07:00
It works! Thank you very mush. Now what I don't understand is why I cant put two vst's in the same patch. Or why that pop up window doesn't appear anymore when you drag and drop something?
edit: I figured out why the drag n drop and menu wasn't working. When I have Usine on my extended desktop, those things don't pop up but when I try it with extended desktop disabled, it works fine. A bug possibly? I'm using Usine 32-bit on Windows 8.1 64-bit
Unread post by nay-seven » 20 May 2014, 08:44
for the 2 monitors, can you please create a bug report..?
I will test soon, but its always better for us to maintain the bugs list to fix
Users browsing this forum: No registered users and 60 guests
