Guided Randomisation (ish) efforts.
Blaakk
Unread post by Blaakk » 17 May 2014, 04:20
Thought I'd block half of the note numbers of a random midi gen module, to try and make some useable variations. Set up a variable note repeat, which'll (or used to) echo the last note, or series of notes, played and went from there. Spent a while trying to pass the bar list to the synchro module.
Used the bar-list subpatch as shown. Still seems a little lengthy.
Maybe there's a simpler way?WIP patch to help make psuedo-semi-random usable triggerable phrases
I'm a little scared of using the polyphony option. Can mess a lot up if one doesn't know fully what one is doing me thinks. And feel like I have to break OSC listing up into small pieces to keep things happy.
Unread post by nay-seven » 26 May 2014, 11:16
i suppose you need to ask a script guru here..?
