Fixed rack width and scroll
gthibert
Unread post by gthibert » 07 May 2014, 04:16
It could be nice to be able to lock rack width, so when a patch goes beyond the rack vertical space, a vertical scroll bar appears, allowing to scroll the rack up and down...
It's a bit confusing when, in a live situation, I add a patch and the rack width double and every other racks are pushed to the right.
Guillaume Thibert
www.cemproduction.com
CREDO
Unread post by CREDO » 07 May 2014, 17:29
+1
Similarly, it would be nice for the Settings panel to scroll instead too :) - especially frustrating selecting objects w/design tab.
Unread post by senso » 05 Jun 2014, 20:42
the vertical scroll bar is not actually implemented, but I'm thinking on a solution.
but don't forget that in usine it's recommended to minimize patches as much as we can.
