You wrote you're thinking about a tool for tablets. Can you tell us what you are planning ? A kind of remote in the touchOSC style ? An external interface builder ? Have you already started something ? Is it top secret
Usine tablet version
La Tenaille
shamanic bicycle
I understood in previous discussions that vst and complex audio path will be be difficult to manage.
May be some midi/osc patching possibilities in a stand alone tablet version ?
A stand-alone runing mode (not excluding a remote option) for a tablet will be the best even with low audio options.
Thx
Thx
Shamanic Bicycle
multiinstrumentiste - improvisation
mac OSX10.13 - interfaces Olilab Midi/Osc - RME FF800
My Vimeo Julien Lachal
Even if it is only a "remote" for a real instance of Usine, this would be so insanely killer. Ideally you could patch and do all that lovely stuff through the remote interface.
The reason I'm so excited about this is it basically removes any need to create TouchOSC/Lemur stuff -- you already get that level of control (more, probably) as you design your patches/workspace.
La Tenaille
you're right, wiring controlers one by one is hours of work and head scratching...
Hope senso will give his vision, I'd be delighted to collaborate
Users browsing this forum: No registered users and 67 guests
