Midi Synch (wait until beginning of the bar to play)
niggles
Unread post by niggles » 12 Apr 2014, 08:49
I know with audio you can use the synchro so it only begins to play / record at the interval you specify i.e you can set it to bar and click record and it won't do anything until the next bar.
I can't seem to find anything for midi though - none of the pins on the piano roll seem to have this (quantize doesn't appear to do it).
Digital Director & Programmer by Day | Musician By Night
iMac Core I7 | Usine | Logic | Leap Motion (loving it)
http://www.tribe404.com
Unread post by nay-seven » 12 Apr 2014, 09:04
there's an inlet named st rec quantize ( for start rec quantize ) , will do the job ?
niggles
Unread post by niggles » 12 Apr 2014, 09:27
Just tried that and if I press play on the piano roll it starts the loop from the beginning but will not wait for a bar or beat (as selected in the Combo box) before it starts to play. I haven't tried it with record though - my main need is for play as the midi will already be recorded.
Do I need write a patch that figures out how many milliseconds left in the bar and triggers play once it's counted down?
Unread post by nay-seven » 12 Apr 2014, 09:47
ok, so you can also ad a quantize data module ( module/synchro Time/ ) between your play switch and the piano roll inlet
niggles
Unread post by niggles » 12 Apr 2014, 09:51
Thanks - will try that.
niggles
Unread post by niggles » 13 Apr 2014, 01:13
Hi again,
I've tried a number of combinations, but can't seem to get it to listen to / send the synchro. I've attached a simple version of what I thought should work.
niggles
Unread post by niggles » 13 Apr 2014, 03:10
RCHIL
Unread post by RCHIL » 15 Jul 2014, 09:55
Hello!
completely new to Usine =) What about getting an audio file to start from the beginning when it is controlled by a looper (RC300 master, Usine slave) .... the file just picks up where it left off, and I would like it to start from the beginning? (using Piano roll patch)
thanks!!!!
Users browsing this forum: No registered users and 43 guests
