How can I do something like:
* mute Rack 1,2,3
* un-mute Rack 4,5
via a patch i.e I want to create a patch with a number of switches which can each send a message to mute / un-mute certain racks.
By mute I mean toggle on / off the rack same as if you clicked the little dot on the right-hand side.
Mute / Unmute Rack with a Switch inside a patch
niggles
Digital Director & Programmer by Day | Musician By Night
iMac Core I7 | Usine | Logic | Leap Motion (loving it)
http://www.tribe404.com
niggles
That doesn't seem so complicated - but I would not have know where to start with that one! Thanks again!!!
La Tenaille
another solution is to use the grid and select lines with switches
