strtoint() and sysex
ceasless
Unread post by ceasless » 25 Mar 2014, 19:17
I'm working on getting text input to display on the Push LCD. I was hoping it would be easy, but I've already hit a bit of a wall:
Code: Select all
        k := strtoint('s');
        writeln('s is '+inttostr( k ));
That results in an error: Error : ''s'' is not a valid integer value
How can I get back the ASCII integer value of 's' ?
sorry, this got posted to general discussion but it should be in patching questions.
Unread post by senso » 25 Mar 2014, 21:49
Code: Select all
var k: integer;
begin
 k := ord('s');
 itrace(k);
end;
this should do the trick?
ceasless
Unread post by ceasless » 26 Mar 2014, 12:14
Yes, that should work! I will give it a try as soon as possible and let you know.
ceasless
Unread post by ceasless » 30 Mar 2014, 16:43
Code: Select all
      for l:=0 to Length(string1)
      do begin
        c :=  copy(string1, l, 1);
        k := ord( c );
The above code throws an 'Invalid cast' compile time error.
1) k is defined as an integer as in the first example.
2) c was first a char, but the StrGet function seems not to be defined so I switched c to a string and used copy with a length of 1.
ceasless
Unread post by ceasless » 30 Mar 2014, 17:24
Code: Select all
      do begin
        c :=  string1[l];
        lcd[0][l] := ord( c );
Switching 'c' back to type char and and accessing the string as an array worked.
Users browsing this forum: Google [Bot] and 194 guests
