Mute button with the pad Kontrol V5
noise2sine
Unread post by noise2sine » 25 Mar 2014, 15:21
I'm using the version 5 of Usine.So i wanted to create mute button for each sampler.So i used the mute module and used the polyphony.The problem after that is that all ptich knobs are corrupt after that manipulation .Is there another way for creating 16 individual mute button for that patch ?
http://www.sensomusic.com/forums/upload ... %201.1.pat
Unread post by nay-seven » 25 Mar 2014, 15:47
can't reproduce
here the patch with the mute switchs
when you apply the polyphony in Usine 5, sometimes some wires move, here was the script comma text, once reconnected correctly seems to work
Download
