i don't know if this is related to hollyhock or to the plugins..
but some plugins for example
http://mdsp.smartelectronix.com/livecut/
or
http://www.kirnuarp.com/kirnu1/index.html
are bahaving strange for example kirnu doesn't even work .
livecut is sometimes working and sometimes not (in v 1.1 is not working, before 1.1 it was better and better with each new version) (both works well in tracktion for me, even if i have some sequence looped)
for me it seems like it is something related like to sync/song position - i dont really know how this things works inside any DAW. In earlier versions livecut just processed one bar of audio then it was silent. when i added to patch sync module (even locla or global) it begun to play - another one bar, when i was handling bars in sync settings again sometimes it played one another bar.. in usine 5.8 it worked well without any of this "funny" bugs.
strange behaviour of some VSTs in hollyhock
yes, i can confirm this , there's something with the synchro on this plug-in . i 'll transmit to the team
next time please use more the bug report page for this kind of report , easiest for us to manage
ok i will post it to bugreport. i just wasn't sure if it was really caused by hollyhock or there is something wrong with that plugins
I've had some issues to - I notice that some Kontakt instruments won't work when using DSP functions, while other Kontak instruments do and then same with Audio Units -> but in all cases it was while using this DSP trigger -> http://www.audiofront.net/dspTrigger.php
I could see the midi data coming in and through the wires, but no sound out.
Digital Director & Programmer by Day | Musician By Night
iMac Core I7 | Usine | Logic | Leap Motion (loving it)
http://www.tribe404.com
same answer,
for specific plug-ins issues, please use more the bug report page for this kind of report , easiest for us to manage.
Users browsing this forum: No registered users and 661 guests
