Hi all, does any know where I can get a simple polyphonic midi keyboard patch for hollyhock?
S
simple midi keyboard patch for Hollyhock?
can you be more precise, you need a poly Midi patch on a tactile screen or you want use an hardware Midi keyboard ..?
Hi , its a poly midi patch that I'm looking for that is compatible with Hollyhock.
thanks
thanks
don't know if someone create a recent one, but maybe you can start with the add on named poly pads 2 , can be a good start ..?
Users browsing this forum: No registered users and 33 guests
