hi folks!
I'm pretty much confused about this fact,
i have this workspace that's real heavy...(693Mo)
and takes soooo long to load.(even makes Usine crash sometimes)
Of course I won't be able to upload it since the limit is 50Mo
is this normal ?
I noticed that when I save each rack separately, the rack that contains the preset manager (and nothing else) is 425Mo
any suggestion ?
thanks in advance
how come my workspace is 693Mo big ?
to be precise, there are 9 racks :
headmaster (preset manager) : 423Mo
FCB (midi control routing) : 106 Ko
Teq (pianoteq + guitar rig) : 299 Ko
KTKT1 (kontakt + guitar rig) : 249 Ko
KTKT2 (kontakt + guitar rig) : 363 Ko
Moog Rig (guitar rig) : 104Ko
CME (midi routing and processing): 13 Ko
Fatar (midi processing and routing) : 13Ko
Click & sequences : 59 Ko
would there be so many parameters to store ? (too many)
I only need about 80 parameters... *multiplied by 32 presets.
La Tenaille
I had this trouble. If your workspace is quite old, a previous version of HH had a bug in preset managers. Opening these old workspaces in a newer version of HH doesn't solve the problem, you have to delete and recreate your preset managers.
edit : perhaps if you create a second preset manager, store everything and delete the old one it works ? not tested.
that sounds like a good advice, and that's what I'm doing right now... i seems to be much better, so far my preset manager rack is 17kO
thanks mate !
thanks mate !
Users browsing this forum: No registered users and 64 guests
