Dispatcher, logical functions, types
AndrewChi
Unread post by AndrewChi » 23 Jan 2014, 23:48
I get different results with using a dispatcher module to send array data to different outputs,
than with achieving the same using several logical =modules, different constants and pass event flow-modules for sending the data.
How are they different? It has another internal timing or something it seems.
Also, could it be that the array-module is responding faster than the matrix module?
When will the array data be lost or not processed properly?
I've been using different modules with different datatypes and I'm getting a bit confused about the do's and don'ts...
Thanks.
Unread post by nay-seven » 24 Jan 2014, 09:43
Can you join some patches example to illustrate those question, please..?
Unread post by 23fx23 » 27 Jan 2014, 16:32
im not sure but i think the dispacher as one bloc delay, i remember having same kind of problem that was solved by using a wait one somewhere (probably on the select of dispatcher)
