Hi
I'm a fresh new user of usine, working on some simple delay mulitiband patch for one live performance.
My problem is that I don't see "clear " inlet, at the patch editeur (juste in/out/delay/num samples/feedback)
I see it on my delay settings panel, and I can activate it manualy from there, but probleme is that
I need to clear the delays buffers (6 delays at series) toghether with "off patch" commande, with one midi controleur.
Authrewise each time I reactivate my multideley patch, it continue where I turne it off.
Doas enyone hade the same problem?
clear inlet on delay module
Hi.i send you an answer on the french section
it's an issue, will be solved in the next version.
senso+++
senso+++
And there is a some other solution to clear the delay buffer?
