I'm just starting to look into IML.
I cannot seem to find where to open the .txt files from the Templates folder inside Hollyhock.
Is it possible to send IML-messages from the command prompt while HH is running?
Thanks!
Internal Messages
you have to differentiate between templates and the send internal message module
the templates are text file you can find in the Usine/templates folders, you can edit and create your owns, to have personal menu when you create wires in patching.
the send internal message module lets you create and interact ( and yes dynamically) in patching mode, delete wires, create modules and so, currently this features is a bit buggy, but will be resolved next release
Ok, thanks!
Can or will it be possible to shoot internal messages directly from an Usine script, the chat window
or way to access the console to open .txt files while Hollyhock is running (for batch-processing purposes)?
Can't tell you for chat window and console, maybe in the future, but yes for scripts
Alright, that's great! looks like I'm gonna have a lot of fun this year
thx!
