Automation in the grid
graphite412
here an example on 3 lines:
fade in, then loop ( with on/off), then fade out
hope it's answer your question ( generally more for the patching forum)
Download
Download
graphite412
Ok thanks that helped a lot. I also appreciate your quick responses. I was not putting the rack into different instances on each line in the grid. I had it set up so that the rack took up multiple lines. That should have been a no brainer.
xX Fiebru Xx
Hey graphite412, have the fade in/out functions worked well for you? When I use them (on mac, have to try on win) things get really horribly distorted. I had to stay at 1.02.011f for that and other reasons.
Users browsing this forum: No registered users and 395 guests
