HID Trackpad Apple
Unread post by cmodica » 05 Nov 2013, 17:30
How can i use the HID module with the TrackPad Apple to remote an XY Pad module.
I want to use the Track Pad to drive the "Real Time Granulator".
thanks.
Unread post by nay-seven » 05 Nov 2013, 18:31
If you add an array display module on the bytes out oulet of the HID module and a listbox on the devices inlet, do you see your pad and activity in the array..?
Unread post by cmodica » 05 Nov 2013, 20:45
Yes, i see my track Pad and there is an activity but i don't know what to do with that ...
Unread post by nay-seven » 05 Nov 2013, 21:00
you have to look at the values sent by your pad and convert them to 0_1 to enter your XY Pad, here an example where a joystick sends 0 to 255 values, i use here a change scale module, but you can also use a divide module
Unread post by cmodica » 06 Nov 2013, 09:30
Thank you i will try as soon as possible. It seems very clear when you explain.
Thank you very much.
I'll tell you about my experience.
Unread post by cmodica » 06 Nov 2013, 16:04
I try but i don't understand how to use the value ... it seems not so easy as i hope. I don't understand what value correspond to the X/Y coordonate value ... Perhap's a combinaison of 6 values :o
I can't see something witch varied from 0 to 255 along the X or Y axes !!!
Unread post by nay-seven » 06 Nov 2013, 16:30
the 0 to 255 is only an example , maybe not applied to your case, can be 0 to 1 or any others
try this: press the left low corner of your pad and note the 6 values
do the same for the left high corner ,
then right hight,
then low right
any logic..?
i suppose you must also have the press ON/OFF state too..
Unread post by cmodica » 06 Nov 2013, 17:33
No i realy don't understand ... it seems never be the same. It's like it depend to a lot of parameter : position on the track pad, position on the screen, pressure, and more ...
I know Apple Trackpad is a complex interface witch can interact with 11 finger and i can find to understand how ... perhaps later ...
iococoi
Unread post by iococoi » 06 Nov 2013, 17:52
there exists an external object for MaxMsp
http://www.anyma.ch/2009/research/multi ... or-maxmsp/
and that's the original code to read the raw gesture data from a MacBook trackpad.
http://www.steike.com/code/multitouch/
that's a quite complicated device. ouch!
Unread post by cmodica » 06 Nov 2013, 19:21
The Max external seems to be very cool and it will be great to have something like that in Usine.
It is totaly out of my compétence ... But thanks a lot.
Perhaps some one who know and understand will can code a new Usine Module for the TrackPad ...
Unread post by nay-seven » 08 Jan 2014, 19:50
someone offer me this device for Christmas, it's a second hand device, but works fine as mouse, gesture on Mac, but i don't have activity in HID mode , only an array of 4 and a fixed value of 2...
have you change something in the system settings before ..?
Unread post by cmodica » 13 Jan 2014, 09:54
hi Nay.
No i didn't change anything in the system but i tried with the Trackpad of my MacBook Pro and not with an external device. But there is no reason to be different ...
I work a lot and i don't have a lot of free time for now, but i will try again and tell you.
Users browsing this forum: No registered users and 95 guests
