it appears it is not possible to rename the additionnal inputs and outputs.
i have a patch with several additionnal ins and outs.
in the rack window they are all called "add in" and it gets very confusing to find the correct one to patch, a miswire can cause huge feedback loops so i suggest there is a way to name specific additionnal ins and outs.
Lost in additionnal inputs and outputs
- senso
will be implemented in futures version: possibility to rename additional in/out
1.02.012k and above
1.02.012k and above
FarfadetFarfelu
Thanks it works in version K.
i have another request for the additionnal in/outs.
Lets say we have an add out on rack 1 and an add in on rack 2.
on the vertical racks window, it would be great to be able to drag and drop add in on the add out to connect them just like the devices or racks !
Thanks.
Thanks.
- senso
much harder to implement...
FarfadetFarfelu
I understand
, for now i'm using busses to have real independant parallel inputs on a rack.
