New add-On: 4DrawLines
Announcements
Unread post by nay-seven » 18 Oct 2013, 16:51
4DrawLines
This patch lets you draw 4 different layers of lines to create Midi sequences.
No complex parameters here, only colored icon to draw, activate or delete each of them.
More infos on its wiki page
Important: Remember you can now directly download add-ons from your browser/add-ons tab, by using the update from internet button.
Unread post by cmodica » 20 Oct 2013, 17:36
Thank You Nay, very funny and musical tool. It is a little bit like a "mini Ianix" :)
There is a stange behaviour with preset manager. I add a preset manager in the patch and I store 2 different sequences. But when i recall a preset the Green line become the same as the blue one ... very stange ? I work with OS X.
Thanks.
Unread post by nay-seven » 20 Oct 2013, 22:48
Thanks Cmodica
and you're right, there's a strange result here, we'll check
edit: you can solve it : right click on an empty part of the patch and in the remote tab, click on repair ID's (sorry you'll lost your preset) but must work.
Unread post by cmodica » 21 Oct 2013, 09:36
It works perfectly. Thank you very much and don't worry for the preset it was just some test.
Now i will try to understand the relation ship beetwin the curve and the note ...
Unread post by nay-seven » 21 Oct 2013, 10:08
yes, actually really basic, can be really improved in the future or adapted to your plug-ins etc..
Users browsing this forum: No registered users and 211 guests
