Is there a way to do that without deleting and recreating all the devices (I have 16 in / 16 out) ?
Reorder device panel devices ?
you can save each device in your library , then recreate by drag & drop and save this as a new set..?
La Tenaille
How do you save a device ? Saving the patch ?
Sorting the devices by name would help anyway.
yes, open your device and use the save patch button in the command menu
you'll see Usine propose you to save a file name my device.device
Users browsing this forum: No registered users and 318 guests
