Euclidean Rythms
noise2sine
Unread post by noise2sine » 04 Oct 2013, 10:00
Does someone can be intersted in creating an Euclidean Rythms patch for USINE ? Like this one :
http://www.youtube.com/watch?v=KKbYdExy3jQ
That one is really cool, but it's not a VST ....It would be really great to be able to use as a VST (sync wiith the host)
Let me know ....
Unread post by nay-seven » 04 Oct 2013, 10:34
I'm working actually in something almost similar, i don't have found yet the fill part, but I've add other possibilities, named "IRS" like Inverse, Roll and Swap , and center balls changes the notes pitch ( manually or by physics engine)
noise2sine
Unread post by noise2sine » 04 Oct 2013, 10:43
whaoouu! Great ! When can we test ;)
Unread post by nay-seven » 04 Oct 2013, 10:48
tomorrow, i think.. ;-)
Unread post by nay-seven » 04 Oct 2013, 12:51
Cool, thanks to share Joffo
noise2sine
Unread post by noise2sine » 04 Oct 2013, 14:08
Thanks Joffo, For which version of Usine is it for ?
Unread post by nay-seven » 04 Oct 2013, 14:15
I suppose it was first for 5.80, but works in hollyhock,
Just resize some objects and drag and drop sounds on the wave display panels
noise2sine
Unread post by noise2sine » 04 Oct 2013, 14:40
it's a very cool patch ! i'm still using the Usine 5.80. I was wondering how i can change the note knob with a knob with midi note names (c1,c#1) would be more practical for me because i'm using it with battery.
thanks
Unread post by nay-seven » 04 Oct 2013, 15:50
you can use a listbox module , you have to write the list yourself , then link the outlet text to the inlet caption of the knob this way:
Unread post by nay-seven » 05 Oct 2013, 17:12
Add-On uploaded ( Seslatero)
