frame rate in midi clock sync
funkyguitarist
Unread post by funkyguitarist » 19 Sep 2013, 21:25
hello
i d like to sync reason to using
reason gives midi clock out.
in hollyhock i used the receive midi clock patch.
when i adjusted the frame to 30 both were in sync.
when i try the same with reason and usine5 usine drifts slowly apart.
i looked into the receive midi clock patch and couldn`t find a way to adjust the frame rate.
can somebody help how to get usine and reason7 in sync.
i m on windows 7 with a touch laptop.
mark
Unread post by nay-seven » 19 Sep 2013, 21:46
Many improvement have been done in Hollyhock for this part, but i suppose you have others reason to use Usine 5
have you try to change the bloc size in in the setup..?
Users browsing this forum: No registered users and 38 guests
