in hollyhock i`missing the timesignature and/or position field that shows on what beat i am in the bar.
i m using spectrasonics stylus rmx to make some bar locked grooves.
its running ok but it alway takes a bar till the vst is in sync.
starting in the middle of the bar kind of throws stylus rmx of the beat.
is there a way to make hollyhock always start on the one of a bar.
many thanx in advance
cheers mark
meter or position field
have you try a fader from the master synchro module..?in hollyhock i`missing the timesignature and/or position field that shows on what beat i am in the bar.
funkyguitarist
thank you nay seven
missed the synchro menu completely
hollyhock is starting on the one everytime i replay
but stylus rmx always takes to bars to sync. after two theres a slight hiccup and then it s there
any idea what i can do about it.
i m using the lastest hollyhock version on mac os 10.8
another short question it seems that holly hock is not remembering the path to my patches.
every time i restart the app i have to set the path again under the global setup.
cheers mark
cheers mark
Users browsing this forum: No registered users and 73 guests
