New version (2.85 beta). Major Update
Announcements
Unread post by senso » 25 May 2007, 20:43
[2.84] Beta -07/05/25
New modules
-Markers module to access to sequencer markers.
-Soft Clipping module.
-New listboxes, and comboboxes interface design modules, with a new design
-A local synchro module, to set a local (patch or sub-patch) tempo. Now you can play grooves with different tempo. Very fun...
-Conductor module to access to the conductors lite commands with a ‘recall’ outlet.
-Get SMPTE position module, to read the current sequencer position.
-A precise timer module for a better communication with external midi synths, Midi clocks, etc.
-Is playing outlet in the sampler/ grain sampler.
New features
-New Midi implementation, introduces the concept of Virtual Midi I/O.
-Each track can receive Midi messages from up to 8 Virtual Midi Inputs
-The mixer adapts its settings to the number of audio In/out modules of the patch.
-Up to 8.0 channels audio buses.
-Mono tracks
-Global mute, solo switches on the dashboard.
-Creation of a collection of buttons on the conductor to recall a scene directly (by pressing them, or by midi learn)
-Implementation of lite version on VST’s (less CPU and memory): Drag & Drop with the [Ctrl] key. See the manual.
-A quick start manual (made by Vincent Michel)
-Multiple Key learn to increase/decrease faders or listboxes value.
Fixed bugs
-the Min value of faders is now correctly stored.
-the key learn now works with the numerical pad.
-the mouse wheel now become inactive when the control is not focused
martignasse
Unread post by martignasse » 25 May 2007, 23:46
well,
happy to be the first to say :
"Well done"
you are so "in phase" with people feedback.
to everyone :
be carreful with the setup window, it's now tabed (first, i believe it was a bug...)
so much thing to test.....
A+
stuartambient
Unread post by stuartambient » 26 May 2007, 16:15
As much as I'm sorry to ask this question I will anyway, will there be a free version available of the latest ? I truly want to become a gold member but it's going to be somewhat of a wait for me at this point.
TIA
SA
Unread post by senso » 26 May 2007, 17:44
hello,
the free version will arrive after the beta test, in, let say, 2 weeks(? - hope)
thanks
stuartambient
Unread post by stuartambient » 26 May 2007, 19:38
Thank you Olivier! I hope to participate as a gold member soon.
SA
lalo
Unread post by lalo » 14 Jun 2007, 16:03
great beta...
noticed 2 little things...
when sampler is in reverse mode ..i hear clicks when i modulate start and end points...everything is smooth and good when in normal play mode
aux1 and aux2 as inputs in tracks are not saved in workspace...
thanx
Unread post by senso » 15 Jun 2007, 10:23
hi LALO,
thanks for feedbacks.
For the future, please try to send bug reports at contact@sensomusic.com. Easier to archive!
