piano roll with incrementing midi file numbers dropping audio
xX Fiebru Xx
Unread post by xX Fiebru Xx » 29 Aug 2013, 01:52
Hey guys, I really wasn't sure where to post because I don't know if I might be missing something. I made a patch for drums based off of the 5x multi sampler, triggering them with a piano roll that increments midi file with each cycle. The problem I am having is the very first note gets dropped whenever the midi file changes. I made a workaraound with a data delay, making the midi file change just a bloc before the next cycle. This worked, but it's not ideal. I was wandering if anyone had suggestions, or maybe has to do with the order in wich Usine handles these events? You can see the patch here,
http://www.sensomusic.com/forums/upload ... ent%29.pat
Maybe there could be a module like the wait 1 bloc, anticipate 1 bloc? You think?
Unread post by nay-seven » 29 Aug 2013, 09:08
Have you try to reduce your BLOC size in the setup (ie 64) ?
xX Fiebru Xx
Unread post by xX Fiebru Xx » 29 Aug 2013, 18:07
Yes, I did but the result is the same. Thanks for chiming in Nay.
Users browsing this forum: No registered users and 410 guests
