hello
i cannot figure out how to add a master effect into the master panel.
i m sure its possible.
many thanx in advance
greetings
mark
master fx
Not in the master panel, but you can easily create a rack with your FX and add all your others racks in its input panel
funkyguitarist
nay seven
yes this is working
thank you
but how can i remove a rack from the input of a rack?
dragging it out is not working
cheers mark
yes this is working
thank you
cheers mark
Just drag it over the trash bin
funkyguitarist
hello nay seven
that worked too although there s only a little spot when the trash bin lights up.
if you don t make it there you cannot complete the operation.
is there a manual where i can find these things other than the wiki manual.
and here is another question.
can we add the solo button on the output of a rack to the interface builder directly.
and if not can we bring a solo function for a rack to the interface builder in another way.
thanx again for your patience
cheers mark
cheers mark
the area is your mouse cursor so it's an habit to take ?
about manual, except the introduction pdf, there's the main manual :
http://www.sensomusic.org/wiki2/doku.ph ... nual:guide
and each object has a ? in its settings panel to point on a wiki page.
About the Solo button, use a rack module ( modules/interface modules/usine panel/) add a solo button and set it to where=IB
Users browsing this forum: No registered users and 81 guests
