Error : Patch Create CalcList
Vincent
Unread post by Vincent » 18 Aug 2013, 18:24
Since this is not a bug (ID#275), I expose the thread here, because I really would appreciate some help about the log file messages.
I have this message in the log-file, and would like to know what it means. It's probably not a bug in Usine but in my patch. Here are the two lines:
Code: Select all
[17:54:34] Error : Patch Create CalcList E:MusiqueUsineWorkspacesV6 [64]Iris.pat Out of memory
[17:54:34] Error : Internal : Patch Create CalcList E:MusiqueUsineWorkspacesV6 [64]Iris.pat
Olivier, you gave me this answer
clear for me:
OK, but what means "out of memory" when memory (16Go) is used at 15 or 16 %?
Does it mean that to "Create ClacList" (which is not clear for me) of that "Iris" patch, Usine needs more than 13,4 Go (available memory) ?
I also have this message in the log-file, and would like to know what it means.
Code: Select all
[17:58:46] Error : Patch Create CalcList E:MusiqueUsineWorkspacesV6 [64]Absynth 5.pat Invalid pointer operation
[17:58:46] Error : Internal : Patch Create CalcList E:MusiqueUsineWorkspacesV6 [64]Absynth 5.pat
In both cases, I decide to restart Usine and it freezes when closing with a Windows access violation message I don't have time to read.
Could we have some infos about the logfiles error messages?
best regards,
V
vincent michel
composer & novelist
Users browsing this forum: Bing [Bot] and 34 guests
