When MIDI control is assigned to a switch that is part of a group, it does not turn off the other buttons in the group. It would be helpful if it did.
Thanks.
Make group switches work with MIDI learn
I'm not sure I understand but I works as expected in Hollyhock.
Thanks for getting back to me Olivier,
I have assigned 2 switches to group1. If I understand correctly, they should operate like "radio buttons" where if I turn one switch on, the other turns off. This works fine for me.
Next I assign a MIDI controller to each switch. When I trigger one switch via its assigned MIDI control, it does not turn off the other switch.
Maybe I have missed something?
Regards,
Scott
Scott
I've also tested and works fine with my BCR 2000, even in motorized mode..
Depending of you controller, test different mode ( absolute/relative/toggle) in the remote tab of your switches
Ok. I'll try again. (It struck me as strange that this wouldn't work. It's more likely my mistake.)
Thanks.
Thanks.
Regards,
Scott
Scott
Users browsing this forum: Google [Bot] and 12 guests
