controlling a parametric eq via OSC
XpiR
Unread post by XpiR » 08 Aug 2013, 17:28
I'm trying to control a parametric eq through my android phone / TouchOSC.
I still think it should be very easy, but I don't find any solution after many tries...
TouchOSC side : XY pad sending OSC messages
Usine side : buses collecting X & Y
But where are the inlets where I have to send my buses to ?
mouse x & mouse y just have outlets...
Thanks for your help.
joffo78
Unread post by joffo78 » 09 Aug 2013, 09:44
Hi. If you want to replace your mouse by your phone i advice
You to use win remote app.if you try to remote a xy module i
Think you are ysing the wrong way
XpiR
Unread post by XpiR » 09 Aug 2013, 17:58
Actually my question was a kind of stupid, as I was deeply concentrated on x & y potential inlets.
Of course the Parametric EQ has gain & frequency inlets, and those are easy to control via OSC.
Anyway Joffo thanks for helping, I didn't know Win Remote, I just downloaded it and it could be useful for other purposes...
