I used to toggle a switch with a momentary CC in Usine 5.8, but I can't do it on Usine 6. My usine switch is in toggle mode, my footswitch sends 127 when pressed and 0 when released.
Any idea ? Thanks
can't toggle a switch with momentary CC
ceasless
I wonder if it can be accomplished using Midi input and feeding data2 to two '=' logic modules, setting the output of the first to 1 when data2 = 127 and the output of the second to 0 when data2 = 0.
La Tenaille
Hi ceasless,
I'm sure I can find a solution with modules, but midi learn is much simpler. I'll have a look again on monday. I still have some MIDI troubles elswhere in my workspace.Thanks for helping
