Send Data Bus
waolelaid
Unread post by waolelaid » 01 Aug 2013, 07:34
Hi i try to start 2 tracks with the module "patch on off" so i try to do like in the picture but it doesn't
work the data bus never receive the message of the switch nevertheless when i click on the
white square to see the console i see that when i clik on the switch it send 0 and 1
but nothing happens when i wire a trace module (always stay at 0)
so how can i do to start the 2 tracks at the same time ?
thanx for your answers this is for Usine 5.80 :D
Friedrich Nietzsche
joffo78
Unread post by joffo78 » 01 Aug 2013, 09:44
hello it's probably because your patch is off with the module patch Imageon/off
if your desactivate your patch, nothing is calculated
you have to put your on/off module in another place.
like this :
waolelaid
Unread post by waolelaid » 01 Aug 2013, 10:17
hi joffo , i don't understand your answer , the engine of Usine is on and the track is on too
so what must i do why a sub patch
thanx
Friedrich Nietzsche
joffo78
Unread post by joffo78 » 01 Aug 2013, 16:08
making a module on/off in a patch is like you 're stopping audio engine on the patch. So your bus dosen't receive information when it's in the patch
waolelaid
Unread post by waolelaid » 01 Aug 2013, 16:44
Hi joffo i Agree with you but it doesn't explain me how i must do
i don't understand your patch in your patch the switch is of
so it's the same as i did
i don't understand
Friedrich Nietzsche
joffo78
Unread post by joffo78 » 01 Aug 2013, 16:58
could you send me your patch that i look to the problem ?
waolelaid
Unread post by waolelaid » 01 Aug 2013, 20:01
patch
here it is when i click on the squares of all the connection i get 1 but all stay at 0
thanx and excuse me to annoy you with this
Friedrich Nietzsche
joffo78
Unread post by joffo78 » 01 Aug 2013, 22:28
i made this patch for you.
I hope it will help you to understand your problems.
waolelaid
Unread post by waolelaid » 02 Aug 2013, 08:20
Hi joffo , your patch works very well
i never found this by myself put it in a sub patch !!!
i keep it preciously i search since 2 weeks but i'm
tired to always ask for little things like that i have some
things that i gave up because i don't understand the logic
of Usine
thanx once again
cheers : :D
Friedrich Nietzsche
joffo78
Unread post by joffo78 » 02 Aug 2013, 09:17
hello waolelaid, don't desesperate and don't worry for this. The forum is here for that ;-). usine is a very powerfull tools to make anything !
So it's normal that learning is a little fastidious. Nethertheless is more easy than other one like max pure data processing etc...
Users browsing this forum: No registered users and 28 guests
