does anyone interested to make a model of this ?
joffo78
Unread post by joffo78 » 28 Jul 2013, 22:58
http://fr.audiofanzine.com/bien-debuter ... space.html
Hi .i wonder if anyone have any idea to make a patch with XY that permit to apply there transformations
LevraiBernardo
Unread post by LevraiBernardo » 29 Jul 2013, 00:42
Hi Joffo,
Look ahead in the Audiofanzine forum. You'll find a demo of a Max patch with vertical position for sound sources. I'm gona try to translate it for Usine (but the model seems to be a little "glitchy").
Many (good) advices to throw far away a sound, or make it closer (filters, reverbs...) in the forum too.
joffo78
Unread post by joffo78 » 29 Jul 2013, 10:54
I made this : binaural pan
That use ambience reverb plug :http://magnus.smartelectronix.com/#Ambience.
I'm not really satisfated yet. If someone could improve that.
joffo78
Unread post by joffo78 » 29 Jul 2013, 17:47
here a example of a multi binaural panner: http://www.sensomusic.com/forums/upload ... phonic.wkp
Ball number 1&2 are ears, other are sources
waolelaid
Unread post by waolelaid » 29 Jul 2013, 20:26
Hi joffo for which version is your example ? Usine or HH cause i don't use HH too much difficult for me
thnx in advance
Friedrich Nietzsche
joffo78
Unread post by joffo78 » 29 Jul 2013, 21:31
I made it for usine 5. but you need this vst to work : http://magnus.smartelectronix.com/#Ambience.
HH is not more difficult than usine 5. It's just a new approach. for the moment i continue to use both. 5 to work and hh to search and learn.
waolelaid
Unread post by waolelaid » 30 Jul 2013, 07:40
Hi joffo ,thanx for your answer , i've "ambience" so i can test your wkp
for me who know about 0,0001 % of Usine i prefer use Usine rather than
get a stomach ulcer because the manual of HH is the same than Usine
no example with the explanations of the new modules and in fact as i play
with the ancient Add on and as there are no compatibility with them
i'm not able to rebuilt them in HH so for me it's too much difficult :(
have a good day
thanx
Friedrich Nietzsche
Users browsing this forum: No registered users and 29 guests
