setp midi/random midi
it would be nice to send out "no data" uding these modules when in bars mode is fader on the lowes value, and setup the step length(yeah this is possible but its quiet tricky to set correct speed of stepping) and note length (like when i want shorter note length as the step length is for example 80%)
here a patch example which can solve this..?
first part let you select the minimum note, then you change the length of the note
