is it possible to build a user module compatible with usine 5.8 from the code made with SDK 1.01 ?
make Usine 5.80 user module with new SDK ?
martignasse
no, the new SDK isn't compatible with 5.8oli_lab wrote:is it possible to build a user module compatible with usine 5.8 from the code made with SDK 1.01 ?
if you want to make a user module for each usine version, you have to maintain two codebase (one for each SDK)
the right way should be to make the 5.8 module first and migrate it to Hollyhock SDK (wiki page about migration here)
then add Hollyhock specific features if needed (like command, record and remote)
Users browsing this forum: No registered users and 37 guests
