grid preset selection in vsts
seamus
Unread post by seamus » 17 Jun 2013, 07:58
i am trying to use the grid as a replacement for the conductor. before i get into all the magical things you can do with the grid i want to see if i can get it to do some basic scene recall with presets of vsts.
i have a combo box coming out of a vst that is populated with all the presets. In the grid i am able to see vst-program as a choice to modulate. I can get a fader that corresponds to the programs on the vst however the faders value only goes from 0-4. I cannot find where to increase the faders value so i can get more preset selections. It seems strange that it would be limited to 4. I must be missing something.
iococoi
Unread post by iococoi » 17 Jun 2013, 08:43
that is quite odd and happens to all list-style modules..*whispering*could be a bug*whispering*..initially they all have 4 entries, so eventually the data doesn't get updated..
Unread post by nay-seven » 17 Jun 2013, 08:51
right, ( you can add a bug report)
waiting for a fix, you can use a fader to set your combo box
Unread post by nay-seven » 17 Jun 2013, 10:41
I realize that even if you have correct numbers for the combobox, will not be easy to know which is the program number you want...
so you can create a patch like this one ( the script can be deleted, once done):
