track names
bmoussay
Unread post by bmoussay » 15 May 2007, 09:52
Hi Usiners,
Just a small suggestion I've been thinking about for a few days.
It's great to be able to rename tracks, but would it be possible that the name of the track appears also "down the track" (I mean just beside the track number above the track controls (volume, pan mute, etc...). This would allow to see all the track names also when in patching mode.
What do you think?
Rgds,
B.
Vincent
Unread post by Vincent » 15 May 2007, 16:36
Yes Benjamin,
I 've just thought the same thing. But, as you know, the track number appears in the corner of the patch edit window. But yes, the name mirrored in the down part of the track, it's a good idea.
Unread post by senso » 16 May 2007, 10:00
thanks for your suggestion
Normally, should be easy to implement. I'll take a look.
