Hollyhock update : preset file no longer exists
daviche
Unread post by daviche » 03 Jun 2013, 22:37
each time I update Usine, then launch my patches, I have this problem : the AU seem not to be recognized (but the appear in the plug-ins list) and I have this message in Trace : This plug-in file no longer exists.
Who knows what is happening ?
Thanks, guys.
Composer - guitar player
Dell INSPIRON 16 5645
Windows 11
RME Fireface UC - EVO 8
Unread post by nay-seven » 04 Jun 2013, 08:33
Yes, there's still some issue with Au, but we progress
waiting for a fix, you can use alt+drag to replace the missing plug-in
daviche
Unread post by daviche » 04 Jun 2013, 09:12
Ok, thanks.
I tried alt+drag but nothing happens. What result am I supposed to get ?
Windows 11
Unread post by nay-seven » 04 Jun 2013, 09:23
When you open your patch, the missing plug-in is red, you select it
then you use alt +drag with the good plug-in to replace it
daviche
Unread post by daviche » 04 Jun 2013, 09:26
Great, it works !
Thanks.
Windows 11
